12 10s purple truck no more 10s?
thank you! i beat on the subs pretty good at slamology, no problems with them at all, other then the one that shifted the top plate ( was also dropped in shipping)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
so, got some alts on the way, singer alts. FTMFW 3 400a alts should do the trick...
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Hahah...yep... 153.1@32hz-45z Subs unload with windows up when i burp it, Got a few things to try.. But did a 157.8@low 30hz outlaw style..
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
so you lost a lil
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I think once i fix the loading issue score will jump way up... Its wayyyy louder then the SAs were
My roof is broken somewhere, which may be the cause of unloading. Still need to dig deeper into the problem... But windows down its a monsterrr
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Sometimes the metal channel that runs across the roof breaks you might check also on the back wall below the window the channel rite there broke alot so we cut the channel out and epoxyd a 2x6 in there it also gives you sumn to bolt the box to, great build where are you from, like to hear it someday, our chevy pic 20120526_111412.jpg
Team Big Un,Team DB Drive, Team DB Driven, Team Xs Power
Team Ohio Gen, Usaci 2-4 modified champ 5 years in a row
My rear wall, of the wall is about 4" thick... Roof above wall is also about 3" thick, floor is a good 5" thick the "shell" of the wall is built right to to truck, The roof of my truck is 2 layers with about a 1/2" gap inbetween that is rattling and flexing pretty good, Going to stiffen it all up real good,again and see if it helps
Vids do no justice for the amount of flex there is lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Im sure there is alot of flex our chevy with the 8-12" moved a lil air it did about a 157 and broke the channel alot it was annoying cuz it let out a horrible rattle noise when it woud let go, good luck to you on your build seems to be going very well
  • Who's Online   0 Members, 0 Anonymous, 1027 Guests (See full list)
