Amp Mounting Location
CUT BUDDY
I know its not a good idea to mount your amp on the enclosure but what if space was a issue and it was no getting around it. Would some rubber grommets help? What suggestions do you guys have if if someone had no choice but to mount his amps and active digital processor on the enclosure?
00114-1.jpgTEAM MechMan Alternators
If you have to, you have to. I mean there's almost always SOME way around it, but if you have to, rubber grommets or thick & wide weather stripping would probably be your best bet.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
honesty i never had a problem i have 4 amps in my suv all my high/mid amps are on the back seat and my sub amp is on my box and there has never been a problem if ur box is built strong there should be no problem
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
Guest MegaloManiac
make sure you look at your manual of your amplifier to see if you can mount it in any position. some amps have terrible cooling mounting them sideways or upside down.
  • Who's Online   1 Member, 0 Anonymous, 959 Guests (See full list)
