ionsmartparts Posted April 7, 2011 Report Share Posted April 7, 2011 Im planning on getting 2 audioque hdc3s with d1 coils. Im planning on wiring them to 1ohm off 1 amp. They have the direct connect lead wires and i wasnt sure how to connect wires to the spots circled in red. I didnt know if maybe these would work? or if you guys had better ideas. Thanks Quote -2002 Impala Ls -Optima yellow top x 2, big 3 -Pioneer 5.8" touchscreen -Infinity 6.1 Kappa Perfect Components -Alpine type r 6" coaxial x 4 - Audio Que hdc312 x 2 -Mb quart 4 ch. x 2 -knu wire -Audio Que 2200w amp - db electric 220amp alt Link to comment Share on other sites More sharing options...
ionsmartparts Posted April 7, 2011 Author Report Share Posted April 7, 2011 anyone have some ideas? Quote -2002 Impala Ls -Optima yellow top x 2, big 3 -Pioneer 5.8" touchscreen -Infinity 6.1 Kappa Perfect Components -Alpine type r 6" coaxial x 4 - Audio Que hdc312 x 2 -Mb quart 4 ch. x 2 -knu wire -Audio Que 2200w amp - db electric 220amp alt Link to comment Share on other sites More sharing options...
JarrodRobertSchuknecht Posted April 7, 2011 Report Share Posted April 7, 2011 i think your to hook the negative from woofer 1 to positive on woofer 2 then positive from woofer 1 to negative of woofer 2 then run a positive and negatives that are left over from each woofer into amp its been awhile since i did it but if my memory is right then that should do it Quote Link to comment Share on other sites More sharing options...
ionsmartparts Posted April 7, 2011 Author Report Share Posted April 7, 2011 i think thata a 4ohm load Quote -2002 Impala Ls -Optima yellow top x 2, big 3 -Pioneer 5.8" touchscreen -Infinity 6.1 Kappa Perfect Components -Alpine type r 6" coaxial x 4 - Audio Que hdc312 x 2 -Mb quart 4 ch. x 2 -knu wire -Audio Que 2200w amp - db electric 220amp alt Link to comment Share on other sites More sharing options...
JarrodRobertSchuknecht Posted April 7, 2011 Report Share Posted April 7, 2011 im not to sure thats what the stereo store said to do since i told them i was just going to run then in series and do a 1/4 ohm load Quote Link to comment Share on other sites More sharing options...
wizart383 Posted April 7, 2011 Report Share Posted April 7, 2011 You can put two bolts through the box (one for the pos and one for the neg). and use a single ring connector for each pos and neg. and bolt them using a nut on the out side. Quote Link to comment Share on other sites More sharing options...
lem43606 Posted April 7, 2011 Report Share Posted April 7, 2011 i used regular wire nuts to connect mine. been in the box almost a year and hasnt came loose. Quote 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG. Link to comment Share on other sites More sharing options...
ionsmartparts Posted April 7, 2011 Author Report Share Posted April 7, 2011 did you have 3 wires in one wire nut? Quote -2002 Impala Ls -Optima yellow top x 2, big 3 -Pioneer 5.8" touchscreen -Infinity 6.1 Kappa Perfect Components -Alpine type r 6" coaxial x 4 - Audio Que hdc312 x 2 -Mb quart 4 ch. x 2 -knu wire -Audio Que 2200w amp - db electric 220amp alt Link to comment Share on other sites More sharing options...
wizart383 Posted April 7, 2011 Report Share Posted April 7, 2011 (edited) [\ hope this helps out Edited April 7, 2011 by wizart383 Quote Link to comment Share on other sites More sharing options...
TheyDontWantMusic Posted April 7, 2011 Report Share Posted April 7, 2011 just parallel them at the terminal, or run two sets of terminals out of the box, as per the pic above. but, if you can't work out how to do this, the rest of the install may be rather average... Quote Link to comment Share on other sites More sharing options...
