Im planning on getting 2 audioque hdc3s with d1 coils. Im planning on wiring them to 1ohm off 1 amp. They have the direct connect lead wires and i wasnt sure how to connect wires to the spots circled in red. I didnt know if maybe these would work? w70oye.jpg or if you guys had better ideas. Thanks
-2002 Impala Ls
-Optima yellow top x 2, big 3
-Pioneer 5.8" touchscreen
-Infinity 6.1 Kappa Perfect Components
-Alpine type r 6" coaxial x 4
- Audio Que hdc312 x 2
-Mb quart 4 ch. x 2
-knu wire
-Audio Que 2200w amp
- db electric 220amp alt
anyone have some ideas?
-2002 Impala Ls
-Mb quart 4 ch. x 2
-knu wire
i think your to hook the negative from woofer 1 to positive on woofer 2 then positive from woofer 1 to negative of woofer 2 then run a positive and negatives that are left over from each woofer into amp its been awhile since i did it but if my memory is right then that should do it
i think thata a 4ohm load
-2002 Impala Ls
-Mb quart 4 ch. x 2
-knu wire
You can put two bolts through the box (one for the pos and one for the neg). and use a single ring connector for each pos and neg. and bolt them using a nut on the out side.
i used regular wire nuts to connect mine. been in the box almost a year and hasnt came loose.
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
did you have 3 wires in one wire nut?
-2002 Impala Ls
-Mb quart 4 ch. x 2
-knu wire
  • Who's Online   1 Member, 0 Anonymous, 1262 Guests (See full list)
