fox_racin4 Posted April 13, 2011 Report Posted April 13, 2011 Done my share of fiberglass work... but whats the bet way to get it to stick to a plastic door panel? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
MxRacer476 Posted April 14, 2011 Report Posted April 14, 2011 Depends, everyone has a method..... You could lay foil down and make a "Mold" essentially, and them FG T-Nuts into the "base" and mechanically attatch it, or just drill frequent 1/4" holes in the panel to allow resin to penetrate, and anchor down. With a layer on the back side as well.....
stefanhinote Posted April 14, 2011 Report Posted April 14, 2011 Depends, everyone has a method..... You could lay foil down and make a "Mold" essentially, and them FG T-Nuts into the "base" and mechanically attatch it, or just drill frequent 1/4" holes in the panel to allow resin to penetrate, and anchor down. With a layer on the back side as well..... Just adding, First method with nuts is nice if you need to remove the pod, or messed up pod during the process, otherwise trying to get fiberglass soaked through to the other side of the panel off is going to be a bitch.
