nickers Posted April 14, 2011 Report Posted April 14, 2011 If I place smaller fuses in the fuse block will that lower the amount of power the cars electrical will use? For example: my brake lights and door chime are on the same fuse. I have removed the chime, if I lower the fuse amperage will It save current for the system? Sorry if this doesn't make sense. chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go
Autoinnovations Posted April 14, 2011 Report Posted April 14, 2011 No. The fuse is to protect the wire when it goes over that amperage. You will just blow fuses easier You can reduce draw by swapping to led lights and only using whats needed. Like your wipers, the draw little to nothing when there turned off Best way is to upgrade your power supply ie power wire, big 3, alternator ect
