MACnonsence6 Posted April 17, 2011 Report Share Posted April 17, 2011 ive looked up stuff on google and i understand how to make one but i cant seem to figure out how to make a double flare that can be put in a box without having to cut over size holes. I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
speedball1978 Posted April 17, 2011 Report Share Posted April 17, 2011 cut it in half and before you glue the entire box together place it on the baffle, screw the ports in... then fiberglass the other half on.. wa la Link to comment Share on other sites More sharing options...
speedball1978 Posted April 17, 2011 Report Share Posted April 17, 2011 or use a coupler that adjoins the two pieces together.. Link to comment Share on other sites More sharing options...
groundpounder122 Posted April 17, 2011 Report Share Posted April 17, 2011 I need help with this also Link to comment Share on other sites More sharing options...
speedball1978 Posted April 17, 2011 Report Share Posted April 17, 2011 its pretty simple guys.. or you can buy them at partsexpress.com they have 2 3 4 and 6 inch aero ports that can be assembled Link to comment Share on other sites More sharing options...
MACnonsence6 Posted April 17, 2011 Author Report Share Posted April 17, 2011 the od of the 6 is to big and im doing a 5" i was worried that a coupler might mess up air flow I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
speedball1978 Posted April 17, 2011 Report Share Posted April 17, 2011 no the coupler would actually connect on the outside of the pvc if thats the material you end up using, Link to comment Share on other sites More sharing options...
MACnonsence6 Posted April 17, 2011 Author Report Share Posted April 17, 2011 yes i was planning to use pvc alright thank u thats what ill do then beats spending 30 for the 6" aero i wanted to use but the od is to big for my box. does the degree a port is flared to make a difference. I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
speedball1978 Posted April 17, 2011 Report Share Posted April 17, 2011 well when you say degree.. explain that to me Link to comment Share on other sites More sharing options...
MACnonsence6 Posted April 17, 2011 Author Report Share Posted April 17, 2011 the amount that the port is flared ive seen some that are flared flat and some that are half that. I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
