Two Rockford Fosgate BD1500.1's
1. Product: Two Rockford Fosgate bd1500.1's
2. Specs: 1500 x 1 @ 2 ohm Can be ran at 1 ohm, and puts out over 1800 watts
These things are beasts.
3. Description/Condition: One is 10/10 electrical wise and id say its not to bad looking for a 10 year old amp.
The other is broken, when it turns on the ground gets super hot...the ground is also stripped and I couldn't get it drilled out, the ground is shot. (ground was shot when I got it, and then it stopped working) You could hardwire with solder if you wanted though. I drilled from the bottom of the terminal and put in another screw to use this amp, but I'd recommend replacement of the terminal and I can refer you to a company that can fix the amp and replace the terminal. Hardwiring with solder would also work as well.
4. What you are looking for: : $425 SHIPPED :drink40:
WORKING AMPS:
One decent amp that does 2500+ @ 1ohm
OR
Two 1200+ watt amps @ 2ohm
5. Pictures of your item for trade:
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
trade pending
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Trade no longer pending, price raised and listed on ebay...sorry dudes theres two BROKEN amps on ebay going for $425.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
