Babyjuice Posted April 19, 2011 Report Share Posted April 19, 2011 Anybody ever use one?? If so how the hell do you use it? BABYJUICE Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted April 19, 2011 Report Share Posted April 19, 2011 Can't be too different than a regular multimeter...what do you need to measure? If it's your amp settings set it to ACV (v with a little ~ above it), if it's your voltage in your car set it to DCV (v with a ___ and ---) above it, if it's resistance set it to ohms (Ω). Put the red test lead in the VΩ and the black lead into the COM. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
Babyjuice Posted April 19, 2011 Author Report Share Posted April 19, 2011 The dvc has 5 different settings (1500,200,20,2,200m) what do I do with that? Also the acv has 5 settings (1000,200,20,2,200m)...and the ohm has 7 settings(20m,2m,200k,20k,2k,200, and an arrow with a T above it) that's why I'm confused idk what to set it at BABYJUICE Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted April 19, 2011 Report Share Posted April 19, 2011 Well on DCV and ACV set it according to how many volts you're trying to measure. For example if you're measuring up to 200V set it at 200V, 200.1 will probably say error. In a car you shouldn't need DCV to be set above 20. ACV most likely you'll set at 200 to set an amplifier or do tests on a house. Ohms set at 200 I believe but don't remember because my TPI I use does it automatically. Just move through the ohms one till it shows what the coil's resistance should be, it'll either read error/ouch, or the resistance on the coil. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
Babyjuice Posted April 19, 2011 Author Report Share Posted April 19, 2011 Ok I'm gonna fiddle around with it..thanks for the help hopefully I can get it figured out BABYJUICE Link to comment Share on other sites More sharing options...
