crossover question
ham4864
would i still have to use a active crossover if my 4ch amp has a built in crossover.(i want to get some mids and highs)i would assume no as long as i set the gains accordingly.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
most amps crossover will not be enough to run active. the simplest reason being the high pass filter goes to about 400hz. a tweeter needs to be crossed over at 3000-8000hz, depending on the setup. sending a tweeter 400hz+ will kill it.
ok so the lower 400hz would kill it but isn't 3000hz more than 400hz or is the 400hz to low of a frequency.if im correct
2009 bmw 5 series
Head Unit Stock
it sounds like you need to do a lot more research before going active. if you set the crossovers wrong it'll sound like ass.
Thats what i thought this website was for,i am doing research.I just want the most power and best sound.
2009 bmw 5 series
Head Unit Stock
it is, partly. getting a person from 0-100% is not what the forum in intended for. there are write up and stuff to get you 50% of the way. then you come here to sort out the kinks. just do a little google searching, read on BCAE1.com, you will get there.
If you have a crossover supplied with a component set, use it and switch off any x-over on your amp(s). They will be perfectly designed to work with the drivers while the x-over in an amp is generic and may not match the drivers x-over points or slope as well.
a seperate active crossover can work well IF you set it correctly, taking the mids and tweets and their needs into account.
My $.02
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
  • Who's Online   0 Members, 0 Anonymous, 837 Guests (See full list)
