barnmaster98 Posted April 26, 2011 Report Posted April 26, 2011 so at the moment i'm creating a wiring diagram to put true keyless push button starting in a future project ford ranger, complete with 3 push buttons (accessory, ignition, and cranking) and reed switch. i was wondering what the ignition 2 wire is for in the wiring harness connecting to the key part of the ignition, do i need to supply power to it while it is cranking or is just using ignition 1 sufficient enough for getting the vehicle started? or if i do need to supply power to ignition 2 would i be able to just use the voltage from the wire going to starter solenoid. any help would be nice seeing as when i do get a chance to create all the wiring harness i'd like to have it together and just be able to disable the steering lock and plug it all in. has anyone out there done a similar project? Quote Currently: 2012 mazda 3 skyactiv sport Mtx 300 amp 10" alpine sub Stock head unit Everything else stock (RIP) 1997 Ford ranger splash reg cab mtx 300 amp 10" alpine sub Sony deck Sirius player placed in where my passenger airbag should be Aftermarket power door locks Aftermarket alarm
