My way to 153.2dB @ 26Hz. Ford Express with 4x 15"
Back in 2009 we were only allowed to use Bass Race cd 3 or 4 in the swedish Bass Race comps, so I switched to Bass Race 4 and gained some and did a 148dB+ Bass Race run.
After that I wanted to do the 149.9 class, so here we go:
Then it was time for the baffle to have a little talk too my saw.
I guess that this isn´t optimal for the airflow so I did some more cutting...
and added these.
Personal bests:
dB Drag: 163.4dB (2004)
Propper Droppers: Average: 150.5dB. Peak: 153.2dB @ 26Hz (2010)
EASCA dBL: 152.2dB (music)(2010)
And then these...
And since I had BIG "holes" between the carbody and the box I made these...
Personal bests:
I will paint the port again since I touched it before it was dry :rolleyes:
Personal bests:
Some hairtricks, I will post videos with open door later on.
Personal bests:
Personal bests:
The re-build did gain some ;)
I got a second M44.
Moved the M44 to see if I can fit two of them, it will work but it´s TIGHT, the amp will be "inside" the door when it´s closed.
Personal bests:
Tight but I can still close the doors :)
Went to Stockholm with these in the box (there´s 5 off them). (I live in the south of Sweden, around 450-500km from Stockholm.)
You always have to look out for the police in Östergötland, but this was extreme ;)
The cracked roof
Out with the seats.
Thomas Holst, trying to weld.
Personal bests:
Looks like he are doing it right!
But the welder was $hit and some welds had to be re-done.
Test inside the car:
Welded in place, will be needing to do some more welding when I get my hands on a better welder.
In Stockholm you need a guarddog! ;)
Personal bests:
Started to take the dash out, didn´t get further than this..
A friend asked me if I could come to his comp last weekend so I had to do something to keep the steel from flexing in the back (it was only welded in the front before) so I did this.
More will be done later on.
In Bass Race Rikard did 146.8 in the quali and I did 146.9, tight ;)
In the final we both had problems, Rikard with his RCA and I had problems with a lose windscreen..
But I guess that 153dB on music isn´t that bad when the windscreen is flexing like crazy.
Personal bests:
I was at a local comp and did little gain, 154.2dB not much, but on the other hand the car looked like this:
Tested 20Hz and did 142.xdB.
Put On - Young Jeesy with open door.
And as always something breaks on the car...
Personal bests:
