hi im new at this i am looking to put speakers in my car it has an alternator that puts out 85amps and 12v i did the math and found that that is 1020 watts however this is not factoring in the battery in my car the speaker im looking to drop in are about 1660 watt is it possible to put theses in my car i rlly need help!
What speakers are you looking at?
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
2 12in and 2 10in kicker subwoofers @ 300 wats max each
4 dpa audio 8 inch mid bass and 2 dpa tweeter with 2 30 wat max alpine 6.5 inch speaker in a box me and my friend put together
the box with the dpa is puting out a total load of 460 watts at 4oems
Ok can you list the actual RMS rating for these speakers.
And if you plan on putting 10's and 12's together in the trunk. Bad idea. One or the other.
All 4 dpa put out 460 max or 460rms>?
2011 Subaru WRX
In the works:
the dpa max at 460 im not sure abou the rms of those speakers
i know the kicker have a rms of 150
but why chose between the too they are essentially the same speaker just different sizes?
sorry to be nit pickey i just am currently running these off receives in my room and they work no problem together
but your gonna be putting them in a enclosed trunk the subs emit different waves which will end up fighting each other. Go with one or the other for the trunk.
230 RMS for the Dpa so each speaker is about 60rms
So you need a 4channel amp that runs about 75rmsx4
And get your self a 300.1 mono amp for your subs and call it a day.
2011 Subaru WRX
In the works:
Speakers aren't what you should be worried about drawing current from your car electrical. Yes it's an end factor, but the amplifier is what you should be concerned with.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
ok thanks but the car i am puting them in is a wagon so will they still conflict?
and the dpa are wired together in the box with coils so they just have 2 wires running off them
you can put them in whatever you want.
2011 Subaru WRX
In the works:
@dwright27 ok so then what amp would you recomend? and how much power can i expect my car to put out with out replacing alternators or adding batteries?
