hey guys, i need to build a new box for my subs but im a big noob when it comes to dimensions :/ , can anyone help me out on building a box? i have two 15in mmatt dreadnauts and im trying to make them preform at their best. the only problem i have is the width of the box has to be 42in or less, and the height/width (preferable width bigger than height) cant be more then about 20, http://www.mmatsproaudio.com/s_dread.html, http://www.mmatsproaudio.com/pdfs/Recommended%20enclosure%20sheet%202011.pdf
i'm kind of a lazy reader :pardon: , but i'd love to help here.
make a list answering the following:
how much power are you giving them?
what do you want the box tuned to?
exact(measured)maximum dimensions LxWxH:
what kind of car do you have?
which way are the subs going face (up, toward you or away from you?
any preferences on where the port is located
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
how much power are you giving them? using a mmats 3500.5 wiring subs down to .5ohms
what do you want the box tuned to? ehh whatever will sound the best and be safe, 32?
exact(measured)maximum dimensions LxWxH: 42,27,22 maxx
what kind of car do you have? '02 jeep grand cherokee
which way are the subs going face (up, toward you or away from you? facing up
any preferences on where the port is located? what ever would be the best, up of firing rear
thank you so much :)
sorry i didn't get back to you earlier. i've been hella busy lately but hopefully i can make you a design by Tuesday. maybe i'll have some time tomorrow, but tuesday or wed for sure
actually, i could pry play around with torres and get you some specs pretty quick, if you want me to sketch it for you, that's gonna take a while.
Edited by 412 CVX
More box builds
heres the specs. i'll see what i can whip up on sketchup.
edit: changed the #of common walls to 2. changed the tuning about 1/4hz. no biggie. onto sketchup!
Edited by 412 CVX
More box builds
