Can Anyone Get Me Box Plans.
Jcoleman134
Hey guys i want to build a new box. And was wondering if anyone could get me plans, Heres the specs for the subs (theres 3 of them btw)
Qts: .375
Qes: .49
Qms: 1.506
Fs: 25.5 Hz
Re: 1.8
Vas: 157 L
Mms: 90 g
Bl: 7.2 T*m
SPL: 89.1 dB
Sd: 510 cm^2
Xmax: 9.1 mm
Voice Coil: 50 mm
Magnet Width: 5.250"
Cutout Diameter: 11.000"
Mounting Depth: 5.000"
Weight: 8 lb
Total Height: 5.600"
Displacement: .04 ft^3
Outside Diameter: 12.000"
Box Size Suggestions Outline
Spec
EHQS12 Subwoofer
Sealed ( small )
1.2cF
Sealed ( ideal )
1.5cF
Sealed ( large )
2.0cF
Vented ( ideal )
2.0cF Tuned to 30Hz
Vented ( DDLoud)
2.0cF Tuned to 35Hz
im going to go get some measurements of the space i have. i cant remember off the top of my head.
Ok measurements are 28inches in depth, 34inchs wide, and 18inches high.
go ported.. with those specs you got some space to work with.. is this in a trunk? u wont be able to fit 3 12s across with ur 34" you could try your subs firing up in a /\
.O
OO
do you already have your subs? you might be better off with 3 10s or 2 15s.. but if youre experienced in some wood working, you can mess with some angles.. /¯¯\
hit me up on aim if you got any questions or suggestions.. quadx4
- Infiniti QX4 - - 2 Digital Designs 9917s - - Digital Designs Z1 - - Digital Designs C3b -
  • Who's Online   0 Members, 0 Anonymous, 2303 Guests (See full list)
