JERSEY Posted May 21, 2011 Report Share Posted May 21, 2011 ok i have 2 L7 15s dual4 now the manual say that - The dual 4Ω woofer will provide a 2Ω load wired in parallel or 8Ω load wired in series. ok now on the 12 volt website it says Option 1 (parallel/parallel) = 1 ohm load Voice coils wired in parallel, speakers wired in parallel Recommended Amplifier: Stable at 1 ohm mono Option 2 (series/parallel) = 4 ohm load Voice coils wired in series, speakers wired in parallel Recommended Amplifier: Stable at 4, 2, or 1 ohm mono . So which is the right ohm Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2011 Report Share Posted May 21, 2011 the right ohm load is dependent on the amplifier you use. an audioque 2200d wired at 1 ohm should power them perfectly. Link to comment Share on other sites More sharing options...
alehound Posted May 21, 2011 Report Share Posted May 21, 2011 the manual is stating that one speaker will provide 2 ohms in parallel. if you add another speaker, that load drops down to 1 ohm. Patiently waiting until 2016...the year in which I likely get to 300 posts... In which then, and only then, will I finally be able to get me some more decaf... Link to comment Share on other sites More sharing options...
