Nick0118 Posted May 22, 2011 Report Posted May 22, 2011 Ok so i have a DC level 4 15, im gonna build a box for it but have no idea how to tune it or even make a ported box it would be great if you guys could help me design one or something its going in s10 ext. cab, and eventually im gonna buy the dc 1.2k amp EVENTUALLY Quote
bumonskateboard6 Posted May 22, 2011 Report Posted May 22, 2011 There's a 1.2k amp? what dimensions do you have to work with? Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Nick0118 Posted May 22, 2011 Author Report Posted May 22, 2011 There's a 1.2k amp? what dimensions do you have to work with? basically hieght isnt a problem, i can go about four feet in depth, and sixteen inches wide Quote
bumonskateboard6 Posted May 22, 2011 Report Posted May 22, 2011 (edited) I did a box similar to this one before, both the sub and the port up. EDIT displacement is wrong but 0.03 cu/f won't effect much Edited May 22, 2011 by bumonskateboard6 Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
RickyFriery97 Posted May 22, 2011 Report Posted May 22, 2011 There's a 1.2k amp? what dimensions do you have to work with? maybe ive heard its cheaper then the AQ1200D also Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
Nick0118 Posted May 22, 2011 Author Report Posted May 22, 2011 I did a box similar to this one before, both the sub and the port up. EDIT displacement is wrong but 0.03 cu/f won't effect much ok but do i really wanna tune it that low? just from what ive read it dosent seem right but then again i have no idea about ported boxes Quote
matt402 Posted May 22, 2011 Report Posted May 22, 2011 id go between 3.5-3.8 net tuned to mid 30s. Quote
the Answer Posted May 22, 2011 Report Posted May 22, 2011 There's a 1.2k amp? what dimensions do you have to work with? maybe ive heard its cheaper then the AQ1200D also the 1.2k is very close to the AQ in price, a lil cheaper though. and seeing the power that the other DC amps put out, this should put out some nice power! Quote
Mx833 Posted May 22, 2011 Report Posted May 22, 2011 ext cab trucks work great with sub up, port up enclosures. tune it to mid-low 30's due to the such low frequencies of the trucks cab. Quote
Nick0118 Posted May 22, 2011 Author Report Posted May 22, 2011 ext cab trucks work great with sub up, port up enclosures. tune it to mid-low 30's due to the such low frequencies of the trucks cab. ok well unfortualntly i just found out the guy i bought it from lied to me the sub is actually a level three... how much is that gonna effect the box Quote
