mrbodean Posted May 26, 2011 Report Share Posted May 26, 2011 how to install a battery in trunk? what all do i need to install? Trying to keep voltage up Quote Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted May 26, 2011 Report Share Posted May 26, 2011 A battery, run of power and ground to the front, and a way to secure it so it isn't flying around everywhere. And I'd suggest it being an AGM because you don't want to have anything spilling or breathing in the fumes from a traditional wet cell lead acid Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
BassJunkie Posted May 26, 2011 Report Share Posted May 26, 2011 ^this you can also just ground in the rear Quote 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
DBz Posted May 26, 2011 Report Share Posted May 26, 2011 how to install a battery in trunk? what all do i need to install? Trying to keep voltage up Ground the battery (make sure you sand the metal) Positive from front battery to your rear battery (positive) thats basically it ground your amp. then run another cable from your rear battery positive to your amp positive...its not that hard at all. Quote (2) Kicker L5 12's Alpine IDA-X305 HU Dual Optimas Big three Kenwood EQ RF Components Hifonics Brutus 1K (Subs) Alpine MRP 250 (Mids/Highs) Lots o' sound deadening Link to comment Share on other sites More sharing options...
mrbodean Posted May 26, 2011 Author Report Share Posted May 26, 2011 how to install a battery in trunk? what all do i need to install? Trying to keep voltage up Ground the battery (make sure you sand the metal) Positive from front battery to your rear battery (positive) thats basically it ground your amp. then run another cable from your rear battery positive to your amp positive...its not that hard at all. thanks BDz good info... Quote Link to comment Share on other sites More sharing options...
DBz Posted May 26, 2011 Report Share Posted May 26, 2011 how to install a battery in trunk? what all do i need to install? Trying to keep voltage up Ground the battery (make sure you sand the metal) Positive from front battery to your rear battery (positive) thats basically it ground your amp. then run another cable from your rear battery positive to your amp positive...its not that hard at all. thanks BDz good info... np man, enjoy. adding a second battery always makes the bass more "grungier" and low Quote (2) Kicker L5 12's Alpine IDA-X305 HU Dual Optimas Big three Kenwood EQ RF Components Hifonics Brutus 1K (Subs) Alpine MRP 250 (Mids/Highs) Lots o' sound deadening Link to comment Share on other sites More sharing options...
mrbodean Posted May 26, 2011 Author Report Share Posted May 26, 2011 how to install a battery in trunk? what all do i need to install? Trying to keep voltage up Ground the battery (make sure you sand the metal) Positive from front battery to your rear battery (positive) thats basically it ground your amp. then run another cable from your rear battery positive to your amp positive...its not that hard at all. thanks BDz good info... whats a good agm battery for bout 100 bucks? was bout to go get a 45 buck walmart everlastnp man, enjoy. adding a second battery always makes the bass more "grungier" and low Quote Link to comment Share on other sites More sharing options...
BassJunkie Posted May 26, 2011 Report Share Posted May 26, 2011 You may be able to get a smaller kinetik or shuriken battery for around 100. I think the smaller xs power batts run around 140 Quote 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
mrbodean Posted May 26, 2011 Author Report Share Posted May 26, 2011 You may be able to get a smaller kinetik or shuriken battery for around 100. I think the smaller xs power batts run around 140 ok... where could i order this xs power Quote Link to comment Share on other sites More sharing options...
Vegas Kid Posted May 26, 2011 Report Share Posted May 26, 2011 You may be able to get a smaller kinetik or shuriken battery for around 100. I think the smaller xs power batts run around 140 ok... where could i order this xs power http://www.audiosavings.com/category/Kinetik-Battery.aspx or http://4xspower.com/purchase/ Quote Link to comment Share on other sites More sharing options...
