ac voltage x ac amperage will be how much power
ac voltage / ac amperage is the your ohm load....
if you are doing just straight burps...
This explains why you come up with different numbers than I do..
Sukka
i learned the same way derrick does it... :shrug:
i tried it both ways & was only hundredths off on wattage... :shrug:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
You can both do it wrong....
Its cool...lol
All good either way
If you do not have a clamp, you can use a known value non-inductive resistor in series with the sub to make an impedance plot. 20 watt 8 ohm are cheap at parts express. Measure the voltage at the amp and across the resistor with the resistor in series with the sub.
Current = voltage across the known resistor / resistor value
Sub resistance value = (voltage at the amp - voltage across the resistor) / current
Edited by bkolfo4
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
You guys crack me up.
Ohm law is a law. It is not one of those things that works different in theory vs. real life.
Voltage x voltage / resistance
Is the same thing as
Voltage x current
And think about it for minute - you just got resistance from voltage / current, so it is the exact same thing. . .you calculated resistance from the same current - it is just skipping a math step. Any error would be slight from rounding, or you are calculating something wrong.
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 8802 Guests (See full list)
