I just wanted to post up a question here to see if anybody could help me fix my old dell desktop tower. Well the deal is every time in try to open any program including mozilla firefox, windows is asking me what program i want to use to open with. :trippy: Did the usual virus scan and etc, but maybe i have a virus? I'd appreciate it if someone here could give me suggestions?
It is a virus/worm you can blame for that.
It could be SWEN. Try the following fix.
http://vil.nai.com/vil/averttools.asp
Scroll down and select the Fixswen.inf download
Save the fixswen.inf file to your local hard disk, right-click on the file and choose install. This is supposed to undo registry changes made by SWEN
It could be Sircam
http://securityresponse.symantec.com...oval.tool.html
Run these online scans too
Panda http://www.pandasoftware.com/actives..._principal.htm
Trend Micro Housecall http://housecall.trendmicro.com/
After cleaning with the scans, if “exes” still won`t work use the “exe file association” fix here
http://www.dougknox.com/xp/file_assoc.htm
If you know your pc skills you can also try this to fix your issue:
start in safe mode.
go to start, run, and type command.com
type copy "regedit.exe regedit.com" (with quotes) into the command prompt
it may or may not give you an error.
now (in the command prompt) type regedit.exe
navigate to HKEY_CLASSES_ROOT
\exefile
\shell
\open
\command
In the right pane, double-click the (Default) value.
"%1" %*
Type the above like the following characters:
quote-percent-one-quote-space-percent-asterisk.
restart.
Others have used this method:
1. Download, unzip and run Godzilla Fix:
http://www.symantec.com/connect/sites/default/files/KillGodzilla.zip
2. Download, install, update Malwarebyte and run a FULL (I insist FULL scan)
http://en.kioskea.net/telecharger/telecharger-105-malwarebytes-anti-malware
You may be required to reboot during the process.
3. After the scan delete the items found.
Edited by xStatezOfMindZx
2 Rockford Fosgate Punch P3 P3D412 in a 4.75 cu. ft sealed box.
Alpine Type-R SPR-17S 2-way component 6.5"
Alpine SPR-57C 5" x 7" 2-Way Coaxial Speaker (Pair)
RF T1000-1bdCP
Alpine MRP-F300
62.5 SQ Ft. Audio Wrap
Stinger SPC122 Capacitor 1 Farad Chrome w/Blue Neon
Limo Tint All Back 5 Windows
