Toady Posted May 31, 2011 Report Posted May 31, 2011 Can anyone explain to me how to test headunit preouts to tell if they are bad. im having an issue where some of my mids and highs are not as loud as the rest. Ive checked impedance, proper wiring, and voltage everything is fine. I took out the hu and experimented with the rcas between the red and white preout. for some reason when i plug in the white preout by itself is not as loud as the red one when i plug it in by itself. and ive listened around the car at some of my tweeters they are not as loud as they are supposed to be. i just need to know how to test preouts and if possible replace them., it was once a 1500 dollar headunit id hate to repplace it
CaptainPooPyPantz Posted May 31, 2011 Report Posted May 31, 2011 BALANCE & FADER Headunit - Pioneer AVH-P4250 DVD 4 - infinity reference 6.5 a pair of infinity reference tweeters 1 - AudioQue AQ-120.4 amplifier for mids & highs 1 - AudioQue AQ-2200D Monoblock 1 - AudioQue HDC315 KitAudio kerf ported Enclosure 4 - Stinger pro series signal wires 20ft Stinger 1/0Ga power & Ground wires Big Three Upgrade 1 - Kinetik HC1800 (Not Here yet . .Still Saving up for one)
bumonskateboard6 Posted May 31, 2011 Report Posted May 31, 2011 Get some alligator clamps for a DMM and clamp the positive one to the pin on the RCA cable and the negative to the ring around the pin. Don't let pin clamp touch the ring and don't let the ring clamp touch the pin, set it on AC Volts then play a tone and turn it up. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Toady Posted May 31, 2011 Author Report Posted May 31, 2011 BALANCE & FADER there are no balance and fader issues, set to 0 and dead center on both
Toady Posted May 31, 2011 Author Report Posted May 31, 2011 Get some alligator clamps for a DMM and clamp the positive one to the pin on the RCA cable and the negative to the ring around the pin. Don't let pin clamp touch the ring and don't let the ring clamp touch the pin, set it on AC Volts then play a tone and turn it up. i appreciate it man. So as far as the headunit goes while im testing it. Do i clamp the male pin on the rca cbale. or the female preout that the rca cable connects to
bumonskateboard6 Posted May 31, 2011 Report Posted May 31, 2011 Get some alligator clamps for a DMM and clamp the positive one to the pin on the RCA cable and the negative to the ring around the pin. Don't let pin clamp touch the ring and don't let the ring clamp touch the pin, set it on AC Volts then play a tone and turn it up. i appreciate it man. So as far as the headunit goes while im testing it. Do i clamp the male pin on the rca cbale. or the female preout that the rca cable connects to Connect the male pin I'd do it at the end of the cables where they plug into your amp just to avoid pulling the whole deck and tearing it apart. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
