da99jeep Posted June 4, 2011 Author Report Share Posted June 4, 2011 i recently picked up the clarion eq off sonicelectronics its only 60 bucks and has a 6 volt output with 7 band equalizer. linkerthingymabob has a front back and sub out with an aux in space too. love it to death makes a world of difference. se that would work, im looking at getting somethign like that anyway, but i need somethign that will split one source to 4 amps why are you splitting it into 4? and since the output voltage is so high from the eq you could put a splitter in there and not notice to much. but just watch your amp. some amps cant take higher voltages. i know massive audio cant. just know your amp Well, what i was planning on doing was 4 18" subs and 4 AQ1200 to them one to each, therefor splitting into 4 is nescissary. i was gonna do 2 AQ3500 but its almost 500$ cheaper to do the 4 1200's Quote Rear (6) 12" Digital Design 1500 Lightning Audio LA3000MD 3000watt Amp 3 Optima red-top Front Doors Kicker SSMB8 8" mid bass Kicker RS56.2 5-1/4" Component Powered by: Rockford Fosgate Power P400.2 My New Build! Link to comment Share on other sites More sharing options...
D-train-13k Posted June 4, 2011 Report Share Posted June 4, 2011 i recently picked up the clarion eq off sonicelectronics its only 60 bucks and has a 6 volt output with 7 band equalizer. linkerthingymabob has a front back and sub out with an aux in space too. love it to death makes a world of difference. i do like the look of that EQ. i did hear that when setting up the planet audio the adjustment for clip was difficult to get just right. how was this when you set it up? was super easy just taped some wires from radio. plugged in rcas and started tuning. really nice too i love it. awesome. this will prolly be the one i buy. so ill ninja your eq from you Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
toadking90 Posted June 4, 2011 Report Share Posted June 4, 2011 i recently picked up the clarion eq off sonicelectronics its only 60 bucks and has a 6 volt output with 7 band equalizer. linkerthingymabob has a front back and sub out with an aux in space too. love it to death makes a world of difference. i do like the look of that EQ. i did hear that when setting up the planet audio the adjustment for clip was difficult to get just right. how was this when you set it up? was super easy just taped some wires from radio. plugged in rcas and started tuning. really nice too i love it. awesome. this will prolly be the one i buy. so ill ninja your eq from you Quote Link to comment Share on other sites More sharing options...
toadking90 Posted June 4, 2011 Report Share Posted June 4, 2011 i recently picked up the clarion eq off sonicelectronics its only 60 bucks and has a 6 volt output with 7 band equalizer. linkerthingymabob has a front back and sub out with an aux in space too. love it to death makes a world of difference. se that would work, im looking at getting somethign like that anyway, but i need somethign that will split one source to 4 amps why are you splitting it into 4? and since the output voltage is so high from the eq you could put a splitter in there and not notice to much. but just watch your amp. some amps cant take higher voltages. i know massive audio cant. just know your amp Well, what i was planning on doing was 4 18" subs and 4 AQ1200 to them one to each, therefor splitting into 4 is nescissary. i was gonna do 2 AQ3500 but its almost 500$ cheaper to do the 4 1200's those can be daisy chained Quote Link to comment Share on other sites More sharing options...
toadking90 Posted June 4, 2011 Report Share Posted June 4, 2011 and have you thought about doing different amps? or can you get a deal or hookup on the aqs? Quote Link to comment Share on other sites More sharing options...
da99jeep Posted June 4, 2011 Author Report Share Posted June 4, 2011 those can be daisy chained now (im still pretty new to alot of this) it says daisy chained there stable at 2 ohms. but i want 1 ohm for maximum power. and isnt chained togeather meaning they act liek 1 amp? do you see where im going here? i think im confusing myself LOL Quote Rear (6) 12" Digital Design 1500 Lightning Audio LA3000MD 3000watt Amp 3 Optima red-top Front Doors Kicker SSMB8 8" mid bass Kicker RS56.2 5-1/4" Component Powered by: Rockford Fosgate Power P400.2 My New Build! Link to comment Share on other sites More sharing options...
D-train-13k Posted June 4, 2011 Report Share Posted June 4, 2011 those can be daisy chained now (im still pretty new to alot of this) it says daisy chained there stable at 2 ohms. but i want 1 ohm for maximum power. and isnt chained togeather meaning they act liek 1 amp? do you see where im going here? i think im confusing myself LOL basically its like running each amp at 1 ohm. so therefore 2 ohm stable. blah blah. but with good enough electrical you can run them lower if you know what your doin Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
toadking90 Posted June 4, 2011 Report Share Posted June 4, 2011 now just so you know lol im still new too but to me daisy chained is just when you run rcas through one to another not linking them together or making one a slave. but this is the one i was thinking. its 2400 at one ohm so it saves you from having 47 amps and they have output rca things. and at 400 bucks it would only be 800 ? maybe and i have its little brother the 1700 and i love it i played mine for prob 2 hours HARD one night and it only got a little warm. just a thought Quote Link to comment Share on other sites More sharing options...
D-train-13k Posted June 4, 2011 Report Share Posted June 4, 2011 now just so you know lol im still new too but to me daisy chained is just when you run rcas through one to another not linking them together or making one a slave. but this is the one i was thinking. its 2400 at one ohm so it saves you from having 47 amps and they have output rca things. and at 400 bucks it would only be 800 ? maybe and i have its little brother the 1700 and i love it i played mine for prob 2 hours HARD one night and it only got a little warm. just a thought this^ it doesnt creat one giant amp that is only two ohms stable. basically creating one a master and a slave allows you to have an even and perfectly coordinated signal and output to your subs. so that your not having to scope two amps and worry about that little bit of a difference on the xover that could make your system sound weird. basically a dynasty chain is a "make life easier" wire Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
