Why is my alternator charging at 12.8volts....
I have a 2007 scion tc... I just got a new alt for the car and put it in because the old one just looks shot and when i spun in by hand made some horrible noise so im assuming it is shot... lol 7k on stock alt for over a year...
Anyways i installed this new alt and its also 100amp alt which im aware only does about 30 amps at idle but i have had no problems with charging for the entire time i had the car and system in it until about 6 months ago when i noticed the alt was probably going out.
Now the most i see is 12.8-13.0 volts... I have had my car sitting on a charger for 2 days my back 2 deka g31a's are sitting at 12.87 each and the front XS power d3400 is at 13.3 resting... And for some GD reason my car will not charge at 14.4volts anymore... My vlotage will drop into the 11s if i turn up the system to listening levels i had just a month ago... That however would be just into the 13s or high 12's if it was charging @ 14.4 volts. Anyone know what the problem could be?? How to fix it???
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
I dont think its bad alt because my last alt did the same thing... and that was for sure a burnt alt... This is not however..
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Bad ground could cause this??? I will go check the grounds and redo some then lol..
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
yes, there's a saying that goes "your electrical is only as good as your worst ground.". personal experience would be one of my connection weren't soldered, came loose without me realizing and so my batteries wouldn't charge above 12.
Start out boxy, shape as you move along.
Dc Audio
Team Fur
I will have to check into that then thank you sir!!
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
but just my .02 cents just because its a new alt doesn't mean it isnt bad. ive gotten a few alts that were bad right outta the box its a pain but hey its how it goes sometimes. i would take it out and have it bench tested first before redoing all kinds of wiring that might not be the problem.
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
internally regulated so i believe that would mean it is new with the alt... And the alt was benched at autozone right before i got it...
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
  • Who's Online   1 Member, 0 Anonymous, 466 Guests (See full list)
