N0CELL0 Posted June 7, 2011 Report Posted June 7, 2011 Alright, this is my first post on the SMD Forum, so bare with me if I come off as a "n00b". I'm working on my first "major" (in my case any way) build. I've got everything down-packed so far and I haven't had to post for any "help", until now. I've read the "Wire/Fuse Guide" that's been pinned, but I'm still a little confused about what I should do. I made this chart showing what I have so far: But my question is this: Where should I put fuses? What size should those fuses be? Should I fuse the amps individually? Should I just fuse the buss bars? After reading what everyone has said in the forum posts, I have no idea at this point.
sqsux Posted June 7, 2011 Report Posted June 7, 2011 i would fuse every power wire going to an amp from the buss bar as far as fuse ratings, i don't know what those amps call for. probably 250 or 300 for those 2500's. Start out boxy, shape as you move along. Dc Audio Team Fur
JustinWilson Posted June 7, 2011 Report Posted June 7, 2011 I designed this fuse block for my car, feel free to use the design for your own. 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
JustinWilson Posted June 7, 2011 Report Posted June 7, 2011 you have each fuse going to a separate tab so that the fuse rating does not change. fuse your incoming power with a 300a, and each outgoing to the t2500's with a 300a each, 200a for the t1000-4, and a 150a for the t600-2, then finally! fuse the incoming from your D680's with a 300a fuse. Make sure to use wire than can safely carry more than a 300a current. Was this helpful? 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
N0CELL0 Posted June 7, 2011 Author Report Posted June 7, 2011 i would fuse every power wire going to an amp from the buss bar as far as fuse ratings, i don't know what those amps call for. probably 250 or 300 for those 2500's. In the RF manuals that came with the amps, it says the following: T2500 - 300A T1000 - 150A T600 - 150A But I was thinking just fuse everything at the buss bars using 4 300A.
JustinWilson Posted June 7, 2011 Report Posted June 7, 2011 it is 200a for the t1000-4, trust me there and please dont fuse with 4 - 300a fuses, that will mean you need a load over 1200a's for a period of time to blow them, if that kind of amperage tried to surge those wires you could have amp damage, and well total car meltdown at the worst lol. 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
N0CELL0 Posted June 7, 2011 Author Report Posted June 7, 2011 you have each fuse going to a separate tab so that the fuse rating does not change. fuse your incoming power with a 300a, and each outgoing to the t2500's with a 300a each, 200a for the t1000-4, and a 150a for the t600-2, then finally! fuse the incoming from your D680's with a 300a fuse. Make sure to use wire than can safely carry more than a 300a current. Was this helpful? That's an awesome design for a fuse block, I'll keep that one in mind when I'm making mine. And yes, what you said was helpful. And don't worry I'll definitely be using the proper gauge wire (I'm not that much of a n00b! LOL!). Thanks for the help.
JustinWilson Posted June 7, 2011 Report Posted June 7, 2011 you have each fuse going to a separate tab so that the fuse rating does not change. fuse your incoming power with a 300a, and each outgoing to the t2500's with a 300a each, 200a for the t1000-4, and a 150a for the t600-2, then finally! fuse the incoming from your D680's with a 300a fuse. Make sure to use wire than can safely carry more than a 300a current. Was this helpful? That's an awesome design for a fuse block, I'll keep that one in mind when I'm making mine. And yes, what you said was helpful. And don't worry I'll definitely be using the proper gauge wire (I'm not that much of a n00b! LOL!). Thanks for the help. With your RF love I never assumed you to be a noob! I have great respect for the gear as you will see in my sig. Love to help, and I can also do Google sketchup custom designs for anything if you need, just pm me. 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
