2000 Saturn SL1
Pioneer MVH8300bt
2/0 Welding Wire - Front to Back + and -
2 c&d 400mrs, stock front batt, stock 90a alt
stock speakers for now
15" dual 1.4 FMS SS T5 motored sub (mario's old T5) - 2 soft spiders - 1200-1500w rms (thanks amin/mario)
old 3.5cuft@32hz w/50sqin box, sanded and re-stained, also re-shot the bedliner and did a stained logo on front also
25sqft AudioTechnix Sound Deadner, need another roll for doors (thanks coleman)
Knukonceptz signal cables
Temporary Kicker zx1000.1 [email protected] since it goes into protect when wired around or lower than 1ohm (thanks memphis87!)
Lots of work done so far, i was bad about taking pics from beginning to end. Seems to peak in the low 40s, but plays pretty darn flat the way its oriented in the trunk from 33-55.
ill take some vids tomorrow
Edited by Decaf
Were you able to fully eliminate the rattle comming from the rear lights? I have a 2002 saturn sl2 and no matter how much deadener I put the rear lights would still rattle like hell.
sub has been in the car since thursday, ive tried rear firing, forward firing and side firing but my rattles are not from the lights
the lights on the trunk lid or on the rear quarters? i took 3M tough tape and sealed off the vent on the left side and all the holes in the trunk lid that actually led straight outside, i was loosing a lot there
not sure on numbers, seems to be low to mid 140s on very very little power, i cannot get sub to move more than an inch so far, altho its still stiff kinda. box orientation makes it like a 6th order basically. i need to seal off some more holes in the rear deck to get the full effect
The lights on the trunk lid are where most of my rattles were comming from. Where is that vent on the left side located I dont think i have seeled that yet.
u have to remove the carpet on the left side, its the vent that allows air to pass when u shut the doors with windows rolled up, it relieves the pressure but for bassheads it lets all the good pressure out
ill take a picture later today of all the sealing off ive done
i dont have lights on my trunk lid since its a lower model. deadner wont help. ull need to use weather stripping or something to take up the space that allows the lights to move and hit the panel
Edited by Decaf
Ah looks like i have a weekend project. Nice Build btw you never see anyone with subs in a saturn or at least I havent.
you sir need to look into Pioneer-Saturns build log... pretty much the most well known saturn with bass. dual alts, dual 18s in a huge horn.
(mine will not be as elaborate as his by any means)
looks good man..where can i get them got decaf stickers from?
SPY aka Pomegraphics can make them any size you want. He is on caco/csco. I have 8" wide decals for $2 mailed if you want standard white vinyl. PM me if you need one or hit up SPY, great guy
Wish i had that guys car i would be shuttign down most suvs in my area with that.
