my box for 4 10" lvl 4s
scfaust
ok well i had some diffrent boxes to chose from i got the cheap wood for free to build it to make sure it would sound good. if it dont ill go a diffrent rought with the box. but if it does sound good, should i rebuild it with mdf instead of the partical board that i used. i am going to glass the inside just resin some mesh at the corners or should i just rebuild it. i think when i glass it it will sound the same way as if i used mdf or a diffrnt wood cause no matter what both boxes would be glassed so wouldnt it be the same thing? and i got the wood for free so that why i used it.
The box is one of the most important parts to a build, and it's not a place I like to cut corners at all. It's up to you but I would build up a new one.
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
Don't use particle it's not as strong as NSF and considering you have four subs it's not like you're just slapping together a test box. The fiberglass is only as good as the wood it's glassed to.
chevrolet all day er day.
'81 camaro z28 performance
'03 silverado ext cab show and go
Don't use particle it's not as strong as mdf and considering you have four subs it's not like you're just slapping together a test box. The fiberglass is only as good as the wood it's glassed to.
