i think this amp will be perfect for them. they are dual 4 ohm subs right? so you will wire them in parallel to get a 1 ohm load.
how to i wire them like you said?
will i be able to use the switch im using right now with this amp
switch???
I have a switch running from my amp to a switch so i can turn my amp off. Didn't hook it up to my radio yet.
yup you will be able to use that with this amp
ok thanks and last question do you know how big the amp is cause i cant find the measurements
ohhh also i have a 600 watt amp Crossfire Vr600D Class-D Mono amp with that push the subs with the wiring you showed me
Dimensions of amp 10.00"(L)x9.27"(W)x2.35"(H)..
do you know if your amp is 1 ohm stable? and how many watts rms does it put out at 1 ohm if it is?
switch???
Heres some info on my amp http://www.epinions.com/specs/pr-Crossfire_VR600D_Car_Audio_Amplifier
ya i saw that info also on your amp but i cant really find any place that sais its 1 ohm stable so just to be safe i wouldnt wire those subs to your amp like i told you to (in parallel).
so how would i wire it if i would to keep my amp
if you wire it in series you wouldnt get enough power for those subs with your amp. but in the review the person sais their running theirs at 1 ohm and it was rated at 897 watts at 14.4 volts so if you go by that then your amp would be good for those subs.
all i no about my wiring right now is that theres two wires going in the box going to both of my subs but both subs have two wires connecting them
i found this info on your amp.. so that should be good with the subs you got
1. Product:
Crossfire VR600D Mono Power Amplifier
2. Specs:
Mono Class D Power Amplifier
150 x 1 @4ohms at 0.08% THD
300 x 1 @2ohms at 0.4% THD
600 x 1 @1ohm
Rated at 12.5V
Signal to Noise Ratio >90dB
Variable LP X-Over 50 - 250Hz
Subsonic Filter
1. Product:
2. Specs:
600 x 1 @1ohm
Rated at 12.5V
Subsonic Filter
Ok and thanks for all your all your help and can you tell me how i should wire it with my amp just in case
ok, take your subs out of your box, or if you can somehow see the wires without taking the subs out then make sure you have your subs wired in parallel.. witch is how we showed you the wiring link, witch was wiring option 1. positive to positive on each sub and negative to negative on each sub and then get one positive from each sub and one negative from each sub and wire those in parallel to the amp
