i need help find a 4ohm ammp that can push two Rockford Fosgate Punch P3SD412 Shallow-mounts and i dont know what amp is good soo please help me out my range in money is 200 dollars or a litte over 200 but not to high
Thanks!!!!!!!
i think this amp will be perfect for them. they are dual 4 ohm subs right? so you will wire them in parallel to get a 1 ohm load.
how to i wire them like you said?
match all postives and put on postive on amp and match and negatives and put on amp negative
edit: go here http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Edited by Jd1102
will i be able to use the switch im using right now with this amp
use wiring option 1 on this link ^^^
switch???
switch???
I have a switch running from my amp to a switch so i can turn my amp off. Didn't hook it up to my radio yet.
switch???
yup you will be able to use that with this amp
switch???
ok thanks and last question do you know how big the amp is cause i cant find the measurements
ohhh also i have a 600 watt amp Crossfire Vr600D Class-D Mono amp with that push the subs with the wiring you showed me
  • Who's Online   0 Members, 0 Anonymous, 742 Guests (See full list)
