i found this info on your amp.. so that should be good with the subs you got
1. Product:
Crossfire VR600D Mono Power Amplifier
2. Specs:
Mono Class D Power Amplifier
150 x 1 @4ohms at 0.08% THD
300 x 1 @2ohms at 0.4% THD
600 x 1 @1ohm
Rated at 12.5V
Signal to Noise Ratio >90dB
Variable LP X-Over 50 - 250Hz
Subsonic Filter
Ok and thanks for all your all your help and can you tell me how i should wire it with my amp just in case
no problem.. wire it like this My link
Posted (edited)
if you wire it in series you wouldnt get enough power for those subs with your amp. but in the review the person sais their running theirs at 1 ohm and it was rated at 897 watts at 14.4 volts so if you go by that then your amp would be good for those subs.
all i no about my wiring right now is that theres two wires going in the box going to both of my subs but both subs have two wires connecting them
ok, take your subs out of your box, or if you can somehow see the wires without taking the subs out then make sure you have your subs wired in parallel.. witch is how we showed you the wiring link, witch was wiring option 1. positive to positive on each sub and negative to negative on each sub and then get one positive from each sub and one negative from each sub and wire those in parallel to the amp
ok ill have to try this in the morning cause its almost 2 in the morning here
ohhh and the subs i have right now dont have the four ports for the wires so does that mean i have to get more wires
Edited by Iwantabump
your sub should have the 4 ports, 2 on one side and 2 on the other. this is your sub right?
ok let me know if you need anymore help :drinks:
what size wire do you recommend so i don't burn my stuff down
you should be good with 4 gauge wire for power and ground and from amp to speakers 12guage should be good
if my amp cant push the two subs whats the worst that can happen just curious
if you set your gains correctly youll be fine cause those subs are 400 watts rms each and by wiring them at 1 ohm you will be giving each of them 300 rms each. cause going by the specs i found your amp is 600 watts x1 @ 1 ohm. so that should be enough power.
i got my speakers wired up and everything and when i turn the volume up the speakers cut out for like 3 secs then come back on
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
