Bakerman Posted June 14, 2011 Report Posted June 14, 2011 So heres my problem. I have a 2005 Ford Focus. The backlight on my instrument panel isn't working. I've googled, but the only thing I can see as a common problem is the gauges failing, not the backlight. But anyways, the backlight isn't working. I've tested all my fuses, and none are blown. Its odd b/c all my other lights on the display are working. Anyone have any ideas? I'm gonna pull it out tom, see if anything is burnt or loose, and clean all my connections. Let me know if anyone has had this issue before.
bassfiend316 Posted June 14, 2011 Report Posted June 14, 2011 Never had an '05 Focus cluster apart, but I assume it still has a bulb behind it. Maybe it burned out?
