Pretty cool! Now you have me thinking <_<
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Thanks bro, haha u want something like this? go for it bro its cheap and quick and its a no brainer to make one :yahoo:
Yeah for sure want something similar. Thinking about using a 4channel I have lying around with a pair of 3way 6x9 pioneers similar to your speakers and 2 6.5's as well. I'm looking now for a small/cheap agm battery that I could put inside the box to power the amp and maybe a small built in trickle charger to charge the battery.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Im going to be using this, http://cgi.ebay.co.uk/12V-Rechargeable-Li-ion-Battery-CCTV-Cam-6800mAh-2-/300534305520?pt=UK_ConsumerElectronics_Batteries_SM&hash=item45f93d92f0
Should be enough to power that lil amp...
Id go for a few, I like to go overkill on batteries tho.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
This battery should last about 8hours as it states on ebay, so 2 of them is more than enough, i dont want any more because it will be heavy, and this is supposed to be portable lol
Depends on the amount of power that small amp actually pulls. 6800mah = 6.8a/h. But two should be good for what you're wanting to do. :drinks:
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
The website states that it runs up to 8hrs at 6,8amp and the amp im using is 12v 5amp that means im going to have 1,8amp to spare, which will add some extra battery life :woot: besides its not like its going to be on full volume all the time... :good:
Ok so i just though it would be really cool if i could bridge this amp since its 4ch and im only using 2ch, but im not sure if that would work out? please commend
Amp specs:
RMS Power Output: 40w x 4 in 4 Ohms speaker loading
DC Input Power: 11V-14.4V 5A-10A
Input Sensitivity: 200mv
Input Level: 0.2 - 1.2V
Speaker Impedance: 4ohm to 16ohm
Frequency Reponse: 20Hz to 20KHz
The speakers are 4ohm ea
