-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
in paralell
amp + to sub1 + then to sub2+
amp - to sub1- then to sub2-
so i'll have 2 wires runnin out of the positive output from the amp 1 to each sub, and 2 wires runnin out of the negative output from the amp 1 to each sub?
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
or u can have another wire from the positive terminal of sub1 if wanted to
but yes two wires for positive and negative
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i see, thank you all for the help i really appreciate that i haven't been flammed at all yet, but i'm still keepin my options open any other amps out there that u ppl recommend
np
that amp though is one of the only ones i could find that did 1000w @ 2 ohms
there is a rockford fosgate t1500-1bd that does 1000@ 2 ohms but its really expensive
http://sonicelectronix.com/item_8955_Rockf...+T1500-1bd.html
see?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1384 Guests (See full list)
