eric78702 Posted June 28, 2011 Report Posted June 28, 2011 I was wondering if it would be okay to leave 3 inches between the box and hatch instead of 4 inches and if I would loose any db by leaving 3 inches and not 4?
fecupe2001 Posted June 28, 2011 Report Posted June 28, 2011 Every car and application is different, 3 inches might be wrong or not, my explorer get louder with box around 8" away while my swift it´s louder every inch i get the ports closer to the hatch, that rule doesn´t apply in my car, i use 6" PVC ports and the box is about 3.1/2" from the hatch Now, if you are using a port back box and the box is way to tall, it might choke a lot! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
eric78702 Posted June 28, 2011 Author Report Posted June 28, 2011 Every car and application is different, 3 inches might be wrong or not, my explorer get louder with box around 8" away while my swift it´s louder every inch i get the ports closer to the hatch, that rule doesn´t apply in my car, i use 6" PVC ports and the box is about 3.1/2" from the hatch Now, if you are using a port back box and the box is way to tall, it might choke a lot! Thanks man. I hope someone on here has a crv like mine and can maybe chime in.
