Problem with HID ballast...could I fix it if...
Well one of my fog light hid ballast has been screwed for some time now and I was wondering if could fix it by doing a little wire stripping, soldering, and kinda daisy chaining it to the other HID bulb...
For example...Let me get some pics up so we all understand
OK now you guys see those two RED cables and the black and blue one on the last pic I posted of the ballast?
Could I strip those wires and solder some 8gauge wire and run it from the ballast that works to the fog light that doesn't have a ballast? Therefor it would be one ballast powering two bulbs...I have a few distro blocks and fuses I can throw in between the wiring if you guys think I need to.
Guest MegaloManiac
problem would be the exiting oem harness that plugs into the ballast will not be thick enough guage.
also didnt you just get these HID's? so warranty should cover it
  • Who's Online   1 Member, 0 Anonymous, 459 Guests (See full list)
