djm Posted July 3, 2011 Report Posted July 3, 2011 I built an amp rack for my car subwoofer amp, and there are two fans at the bottom (of different size, one pulls more amperage than the other) and they are wired in parallel to a relay which also turns on the amp. (when the amp goes on so do the fans) well the positive and negative for the relay are wired into the amp's positive and negative terminals. i tested it out in my workshop with a ac/dc transformer and everything worked fine, both fans turn on, the bigger fan pushes a little less air and the smaller fan (of better quality) pushes more air (normal) so everything checks out and i go put it in my car, well i turn the car on and the amp turns on...the smaller fan dosent turn on, the bigger fan is going at about 3 times its normal speed (and im talking SELF DESTRUCT type FAST) so i turn it all off and bring it back inside try it again and it works perfectly, so i put it back in the car and it works fine, the next day it freaks out again and has the same problem. i can also hear the fans noise thru the subwoofers. i dont know why this is please help out. Thanks, John Live it Loud!
skittlesRgood Posted July 3, 2011 Report Posted July 3, 2011 pull out the DMM and see if you find any weird voltages. probably wired something wrong. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
djm Posted December 8, 2011 Author Report Posted December 8, 2011 it was a thermo resistor that was hot because it was like 90 degrees outside and thats what caused it to happen only outside Live it Loud!
