w87will Posted October 18, 2007 Report Posted October 18, 2007 Ive been trying to get on Second skins site all day and it hasnt been working for me
Guest MegaloManiac Posted October 18, 2007 Report Posted October 18, 2007 i have used eDead, raamat, dynamat, and ss before
goinpro Posted October 18, 2007 Report Posted October 18, 2007 Linky meglo...which one did you like the best? 2005 Nissan Altima 2.5 S HU: AVIC-D2 Fronts: ARC Audio KAR KS6006 Components AA Poly Mids/ CDT CW-19 Tweets in kicks Front Amp: Profile AP400x2 Rear Fill: None Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps) AMP: RF t10001bd x2 (1400-1500 @ 1 ohm) Wire: Welding Supply/Lighting Audio 1/0 Power/Ground Zero Noise 2.0zn RCA (x2) 260 Amp Iraggi Alternator
w87will Posted October 18, 2007 Report Posted October 18, 2007 Thanks, But nothing still. "Internet Explorer cannot display the webpage".......
Guest MegaloManiac Posted October 18, 2007 Report Posted October 18, 2007 Linky meglo...which one did you like the best? ss man. if u really dont want to spend as much go with raamat
goinpro Posted October 18, 2007 Report Posted October 18, 2007 sweet well ill probably get to it friday if the weather holds up...so we will see 2005 Nissan Altima 2.5 S HU: AVIC-D2 Fronts: ARC Audio KAR KS6006 Components AA Poly Mids/ CDT CW-19 Tweets in kicks Front Amp: Profile AP400x2 Rear Fill: None Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps) AMP: RF t10001bd x2 (1400-1500 @ 1 ohm) Wire: Welding Supply/Lighting Audio 1/0 Power/Ground Zero Noise 2.0zn RCA (x2) 260 Amp Iraggi Alternator
Guest MegaloManiac Posted October 18, 2007 Report Posted October 18, 2007 make sure u wipe down panel CLEAN. so that the deadener adheres to the panel and not the dirt also it be good idea to use a roller if u got one, if u dont use an end of a screwdriver or something blunt to get air bubbles out and stick better
goinpro Posted October 18, 2007 Report Posted October 18, 2007 ok so make sure they are clean...i also did get a roller...i have also heard to just work w/like 12 x12 squares instead of full sheets...any other tips??? sorry for the hijacked thread 2005 Nissan Altima 2.5 S HU: AVIC-D2 Fronts: ARC Audio KAR KS6006 Components AA Poly Mids/ CDT CW-19 Tweets in kicks Front Amp: Profile AP400x2 Rear Fill: None Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps) AMP: RF t10001bd x2 (1400-1500 @ 1 ohm) Wire: Welding Supply/Lighting Audio 1/0 Power/Ground Zero Noise 2.0zn RCA (x2) 260 Amp Iraggi Alternator
Guest MegaloManiac Posted October 18, 2007 Report Posted October 18, 2007 ok so make sure they are clean...i also did get a roller...i have also heard to just work w/like 12 x12 squares instead of full sheets...any other tips??? sorry for the hijacked thread god yes, dont event think u can use full sheets at once lol its harder then it looks for doors. even 12x12 is a stretch. another tip is get some wire loom form home depot and cover the door opener bar(i dont know correct term) with the loom and then go over it with the deadener. you see what im talking about? this pic was taken before more deadener was applied to it
goinpro Posted October 18, 2007 Report Posted October 18, 2007 looks good...i was reading your posts over at ca.com and listened to your videos I am starting on the trunk and then hopefully on my next order I will get to fully do the doors 2005 Nissan Altima 2.5 S HU: AVIC-D2 Fronts: ARC Audio KAR KS6006 Components AA Poly Mids/ CDT CW-19 Tweets in kicks Front Amp: Profile AP400x2 Rear Fill: None Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps) AMP: RF t10001bd x2 (1400-1500 @ 1 ohm) Wire: Welding Supply/Lighting Audio 1/0 Power/Ground Zero Noise 2.0zn RCA (x2) 260 Amp Iraggi Alternator
