Could someone please help me with calculating the correct port length for a Sundown SA-8? It will be getting approximately 500rms via a RF BD1000. .5 to .6 enclosure firing and ported towards the back of a convertible mustang. Also leaning more towards SQ and using 4 inch ports. Any help would be appreciated.
Edited by mcrowdr
if you are honestly after SQ, have someone who designs boxes desgin you one. that way you can ensure you are getting a combination that works well together and not just numbers going off of speculation
1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
The only problem with that is, there isn't anyone in the area that does that. I've built boxes in the past that range from sealed to 4th order bandpass so I can build anything if given the specs to do so.
