spldreams Posted July 14, 2011 Report Posted July 14, 2011 i need some help with a box for a dc level 4 15. it will be powered by an aq 1200. max dimensions are height-15 width-26 depth-24. the sub has to be firing up. and the port im not sure about either slot or aero. i would like tuning to be between 31-33 hertz. for some reason i cant seem to come up with anything that has enough port area.
RAM_Designs Posted July 14, 2011 Report Posted July 14, 2011 You have 4.31ft^3 before sub and port displacements, which is just not enough room to make a proper box for that sub. You're going to have to go larger to get it to work. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
spldreams Posted July 14, 2011 Author Report Posted July 14, 2011 ok, if it goes into another car dimensions would be height-15 width-33 depth-25. that would be 5.78 before all displacements. that should be big enough to work right? im not sure what to do for the port or bracing though.
RAM_Designs Posted July 14, 2011 Report Posted July 14, 2011 Those dimensions will work just fine, assume the 25" depth leaves you some room between the box and back of the vehicle. You can probably cut that depth down a little as well. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
