Freshman6969 Posted July 15, 2011 Report Posted July 15, 2011 welp im being a thread whore today....if i were to buy a newer AQ3500 with the double imputs, and run it WITH my old AQ3500, the one with the single inputs, would this cause a problem? id think the newer one would pull more power then the older one, but having one linked to the other, one master one slave... i dont see as possible because of that, i could be wrong, hence i am asking. opinions? Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
Freshman6969 Posted July 16, 2011 Author Report Posted July 16, 2011 bump Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
fox_racin4 Posted July 16, 2011 Report Posted July 16, 2011 Will not work, differnt amps 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
armykyle1 Posted July 16, 2011 Report Posted July 16, 2011 are the boards completely diff? have you emailed AQ? TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
StreetSlappah Posted July 16, 2011 Report Posted July 16, 2011 Old aq has a 3500 watt board and new aq has a 4300 watt board it will not work. Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center] Build Log http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/ 2005 subi STi 380whp 355whp 17" gold bbs 5% tint all around w/sunglare strip JVC dvd double din Knuconceptz 4ga wiring XS Power! Big 3 8" SAv2 d2 1800 audiopipe
Freshman6969 Posted July 17, 2011 Author Report Posted July 17, 2011 thanks guys, can close this if you want mods, question answered Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
