Full size van
"slightly larger than the savannah passanger van"
looking for ideas, been reading up on SPL going with 12x 12s "1500rms, 2500-3000w" able to play fave music and still run at around 150Db+, 1-2-4 ohm? 20-70Hz budget is around $3.5k for entire setup, batteries, wire etc. everything, any suggestions? or not possible?
2x half-walls foldout into 1 fullwall total air space in front of wall is around
"200 cubic ft 6x5x8" and the boxes would take up around (40" high, 60" wide, 10-20in deep)
looking for MASSIVE airflow for tricks "with sliding door open" at shows, car cruises etc.
Edited by Grelko
Optimus XL-400w amp 2x 10s IMPP 400w 2x something or other in dash 2x 35w radioshack 8" full-range AcDelco factory radio "frankenstein'd from my dead buick" Dodge seats 1984 Chevy G30 full size 1-ton van "Rust Monster" Progress - around 15% primer/patching
Sold the van in 2014, had it about 75% done, never did get the system in it. Bought a 2000 Chevy S10, still using the same amp/subs. Headunit is XO Vision X538. It's 52x4w, has a dvd player, auto flip out 7" touch screen plus alot more and is a single din.
just to make sure noone is confused, each sub enclosure would be right around
39in high, 29 wide,"absolute maximum just double checked the space" 10-20in deep, could actually go up to 26 deep since they swing-out 1 halfwall at a time with grills added.
Edited by Grelko
i'll have them on hinges so they swing out like doors, meet in the middle "fit tightly together, locked in place etc" to make 1 huge wall that i can split back into 2 pieces and have them on the back walls while driving.
hoping to get some pics up soon as i finish covering the walls/ceiling with xtra support for all the speaker weight, youd see what i meant for sure then :)
Edited by Grelko
I didn´t understand almost anything on your last post, but anyways, a 155 dbs @ 30´s with 3500$ seems hard as hell if you wask me because it has to include amplifiers, batts and everything. I would set a lower goal and everything past that goal is a bonus, said that, a 150 dbs it´s way easier to hit.
I would go with something stupid cheap that still can pound the lows, i know american bass has some subs that you can affort and get a massive amount of cone area ONLY IF YOU CAN FIT A PROPER BOX FOR THEM, a couple of AQ or crescendo amplifiers, HO alternator and a few batts, i´ve used SVR batts before and for the price they aren´t bad at all, jus throwing ideas out there, but i honestly think it´s difficult since you are gonna spend a lot of money on wood and wires, head unit and even on mids/highs and amps for those, or you think your demos are gonna be fun just playing subs without hearing any voices? lol
