Here is my idea.
I am designing a ported box for my Dodge Dakota extened cab. The box is to hold 4 12" Kenwood Kfc-w3013. Don't ask why Kenwood I have always like Kenwood. It is a clam shell style box with the ports on top firing into the roof. The box is actually 2 boxes bolted together to form the clam shell. 2 12's on each side.
Now heres the issue.
Winisd says that for a 4cu.ft box I need a port of 14.5 x 2.75 by 21.09L with a vent mach of .08
Bass Box says for the same box I need a port 14.5 x 2.75 by 15..29 with a vent mach of .11
Which is right both have a box tuning freq of 31hz.
Here are the specs on the sub itself if this helps.
Z=4
RE=3.4
LE=1.65MH
SD=.051 SQ.M
BL=10.5 TM
VAS=83.7LITERS
MMS=183.0G
FS=25HZ
QMS 8.250
QES=.910
QTS=.820
XMAX=15.1MM
SENSITIVITY=85DB
FR=34-300
Any help to shed some light on this will be helpful and thank you in advanced.
if i remember correctly(havent used it in years), winisd doesnt take into account the volume lost by the port... that may be the discrepancy
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
I thought that might be the case but.....
Bass Box Pro accounts for displacement of the speakers and port.
Winisd figures the port base on the VB you enter, so to figure the extra displacement from subs and port you follow the following formula....
WP + BT x HP X LP / 1728 = (displacement of port) + SB + SB = (Total Displacemnt) + VB = Total VB
14.5 + .75 x 2.75 x 21.09 / 1728 = .51 + .072 + .072 = .654 + 4.0 = 4.654 Total VB
WP= Width of Port BT= Board Thickness HP= Hieght of Port LP Length of Port
SB= Sub Displacement VB= Volume of Box
I am not sure if I am over analizing this....... Could be me just being anal not sure......
  • Who's Online   0 Members, 0 Anonymous, 2007 Guests (See full list)
