incriminatoraudiodp18'' Posted July 19, 2011 Report Posted July 19, 2011 ok well my friend has a problem with his system. he has 2 orion 15's and a hifonics 1200wat amp. and a engine noise is comming out of his subs. we re wired his ground on his amp and radio. but still tha same problem. wat else r we missing? thanks 4 any comments yall might hav. incriminator audio death penalty 18' dual 1.6 to be exact. hifonics brz2400.1 wired 2 .8 ohms. hifonics hfi 100.4 mids and highs. hifonics zeus 6.5 separates 11mm tweets. 3 300 amp fuses, 0 gauge wire. yellow top optima in front and back. alpine head unit.
bass_stalker Posted July 19, 2011 Report Posted July 19, 2011 are the power wire and rcas running on the same side or near each other? JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
incriminatoraudiodp18'' Posted July 19, 2011 Author Report Posted July 19, 2011 are the power wire and rcas running on the same side or near each other? noop opposite sides. incriminator audio death penalty 18' dual 1.6 to be exact. hifonics brz2400.1 wired 2 .8 ohms. hifonics hfi 100.4 mids and highs. hifonics zeus 6.5 separates 11mm tweets. 3 300 amp fuses, 0 gauge wire. yellow top optima in front and back. alpine head unit.
bass_stalker Posted July 19, 2011 Report Posted July 19, 2011 are the power wire and rcas running on the same side or near each other? noop opposite sides. did he move the ground completely. in my friends car he put the ground in one place and it had noise. but when he moved it the noise went away. also it could possibly be a damaged rca JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
incriminatoraudiodp18'' Posted July 19, 2011 Author Report Posted July 19, 2011 are the power wire and rcas running on the same side or near each other? noop opposite sides. did he move the ground completely. in my friends car he put the ground in one place and it had noise. but when he moved it the noise went away. also it could possibly be a damaged rca yea we moved it 2 a whole different spot. now thats somethin that i havent hear it could be. but we will defiantly try it out. incriminator audio death penalty 18' dual 1.6 to be exact. hifonics brz2400.1 wired 2 .8 ohms. hifonics hfi 100.4 mids and highs. hifonics zeus 6.5 separates 11mm tweets. 3 300 amp fuses, 0 gauge wire. yellow top optima in front and back. alpine head unit.
bass_stalker Posted July 19, 2011 Report Posted July 19, 2011 if its not that. does he have an iPod cable on it. i remember one person on here having a noise issue and it ended up being his iPod cable JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
incriminatoraudiodp18'' Posted July 19, 2011 Author Report Posted July 19, 2011 if its not that. does he have an iPod cable on it. i remember one person on here having a noise issue and it ended up being his iPod cable i dont think so. incriminator audio death penalty 18' dual 1.6 to be exact. hifonics brz2400.1 wired 2 .8 ohms. hifonics hfi 100.4 mids and highs. hifonics zeus 6.5 separates 11mm tweets. 3 300 amp fuses, 0 gauge wire. yellow top optima in front and back. alpine head unit.
