NEED 4 channel amp help ASAP!
k3n12ock
So I just replaced my old 4 channel amp with a newer one (JBL GTO 75.4ii). Now, for some odd reason, I can NOT get more than 1 channel/speaker to work on this new amp. It's either channel 1 or channel 2 but NOT both (FRONT rca's but can't get both speaker channels to play at the same time). Anyone know why this would happen (in general)? I don't think it's my wiring because when hooking the old 4 channel up, everything works as it should. Any thoughts? This is the 2nd 4 channel amp I've tested and have had this happen with.
most likely either a bad RCA cable, see if the opposite side plays if you switch the rca's from left to right, or bad output on HU
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
I tried swapping with all 4 RCA's and same thing. As mentioned though, if I switch back to my old amp, it works as it should.. WEIRD!!!!!
BTW all my rca's are coming off my IMPRINT (PXA-H100) unit. I did disconnect the power to reset it but it didn't help. Would I need to disconnect my HU power too? Also, would I need to disconnect the AUX cable from the IMPRINT as well? Should I switch the setting from FRONT/REAR/SUB to 3way??
  • Who's Online   0 Members, 0 Anonymous, 1032 Guests (See full list)
