eh nope it will not mess with transmission, but if you went with heavy wheels then that would kill everything, all suspension parts, drive shafts, gear box, but tyres will not affect it.
also why are you not concerned about your suspension????????????????????
stock rims and its only one size bigger than stock shouldnt be much change. ive been running the 25's for a few years now
trust me when I say this, I have seen it plenty of times, when you say 25's, you rim size yes???? also on main roads or motor ways, your car will always pull to the left as the road is cambered that way.
no it was on a four wheeler. its 12 inch rims on the front and 11 inch rims in the back. they both have 25inch tires on them
so like a tractor then, I no understand american talk. I am going on what I have seen and fixed on a similar jeep. you can get wider and bigger tyres for it, I have seen em, worked in a tyre places and seen them with even bigger size than yours. why not the same size all round
im not sure why the stock rims are different sizes. id like to do wider tires but i cant go much wider because of the brake parts
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
