2 aq hdc3 12's, on 1 aq2200d, Im buiding a box for my ext cab, the box i have now is like 6 cubes and hits 138 at 33 hz, way to low and not loud at all really.. so im looking to atleast hit 142-145 so im building an L port box, around 4.5 cubes before port and sub disp, so 4 cubes after- ish.
Just wondering how wide to make the port from where the subs are, and how many inches above the bottom of the box to make it, along with how wide the exit should be (?" wide by 15 tall)
thanks
1998 GMC Jimmy 4 Dr.
-SINGER 275 Amp Alternator
-150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back.
-Audioque AQ2200D @ .5 ohm
-2 Audioque HDC3 18's Tuned to 27-29 HZ
-4 Clarion 6.5's
-2 Optima yellowtops
Dude ur in an ext cab truck u should be able to pull a 150 if ta do it right im in a car with 2 hdc3s and was 143.97 @ 31hz that was the first time i ever metered in my life and it was at the headrest. Btw i wasnt sealed off and i only did 1 run on the meter. This was with 2500rms
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Well i need help with the port issues haha.. to get loud
-4 Clarion 6.5's
I would get a good box design from like ramdesigns on here. Enclosure makes all the diff in the world a properly designed and built enclosure will make a huge diff.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
And u might want to try more like 4.5-5.5 cuft for the pair and like 16sq.in. Of port per cu.ft. If i knew how to design boxes i would do it for ya. I can give you my measurements of my 2 boxes one is 32hz tuning and the other is 38hz
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Are they L ported? But yeah sure , and how much does ramm cost to make a plan? :o sounds good too
-4 Clarion 6.5's
The 33 hz one is and its 4.5 cuft net.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
4.5ft3 with 73in^2 of port area tuned to 33hz
Height-17
Width-36
Depth-22.5
Port
Width-4.75
Height-15.5
Length-33
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
That design was from mike at audioque
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
a 150 with 2 12's on 2000w? good joke
  • Who's Online   0 Members, 0 Anonymous, 908 Guests (See full list)
