Dbforlife Posted August 4, 2011 Report Share Posted August 4, 2011 2 aq hdc3 12's, on 1 aq2200d, Im buiding a box for my ext cab, the box i have now is like 6 cubes and hits 138 at 33 hz, way to low and not loud at all really.. so im looking to atleast hit 142-145 so im building an L port box, around 4.5 cubes before port and sub disp, so 4 cubes after- ish. Just wondering how wide to make the port from where the subs are, and how many inches above the bottom of the box to make it, along with how wide the exit should be (?" wide by 15 tall) thanks Quote 1998 GMC Jimmy 4 Dr. -SINGER 275 Amp Alternator -150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back. -Audioque AQ2200D @ .5 ohm -2 Audioque HDC3 18's Tuned to 27-29 HZ -4 Clarion 6.5's -2 Optima yellowtops Link to comment Share on other sites More sharing options...
bassrace Posted August 4, 2011 Report Share Posted August 4, 2011 Dude ur in an ext cab truck u should be able to pull a 150 if ta do it right im in a car with 2 hdc3s and was 143.97 @ 31hz that was the first time i ever metered in my life and it was at the headrest. Btw i wasnt sealed off and i only did 1 run on the meter. This was with 2500rms Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Dbforlife Posted August 4, 2011 Author Report Share Posted August 4, 2011 Dude ur in an ext cab truck u should be able to pull a 150 if ta do it right im in a car with 2 hdc3s and was 143.97 @ 31hz that was the first time i ever metered in my life and it was at the headrest. Btw i wasnt sealed off and i only did 1 run on the meter. This was with 2500rms Well i need help with the port issues haha.. to get loud Quote 1998 GMC Jimmy 4 Dr. -SINGER 275 Amp Alternator -150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back. -Audioque AQ2200D @ .5 ohm -2 Audioque HDC3 18's Tuned to 27-29 HZ -4 Clarion 6.5's -2 Optima yellowtops Link to comment Share on other sites More sharing options...
bassrace Posted August 4, 2011 Report Share Posted August 4, 2011 I would get a good box design from like ramdesigns on here. Enclosure makes all the diff in the world a properly designed and built enclosure will make a huge diff. Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted August 4, 2011 Report Share Posted August 4, 2011 And u might want to try more like 4.5-5.5 cuft for the pair and like 16sq.in. Of port per cu.ft. If i knew how to design boxes i would do it for ya. I can give you my measurements of my 2 boxes one is 32hz tuning and the other is 38hz Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Dbforlife Posted August 4, 2011 Author Report Share Posted August 4, 2011 And u might want to try more like 4.5-5.5 cuft for the pair and like 16sq.in. Of port per cu.ft. If i knew how to design boxes i would do it for ya. I can give you my measurements of my 2 boxes one is 32hz tuning and the other is 38hz Are they L ported? But yeah sure , and how much does ramm cost to make a plan? sounds good too Quote 1998 GMC Jimmy 4 Dr. -SINGER 275 Amp Alternator -150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back. -Audioque AQ2200D @ .5 ohm -2 Audioque HDC3 18's Tuned to 27-29 HZ -4 Clarion 6.5's -2 Optima yellowtops Link to comment Share on other sites More sharing options...
bassrace Posted August 4, 2011 Report Share Posted August 4, 2011 (edited) The 33 hz one is and its 4.5 cuft net. Edited August 4, 2011 by bassrace Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted August 4, 2011 Report Share Posted August 4, 2011 4.5ft3 with 73in^2 of port area tuned to 33hz Height-17 Width-36 Depth-22.5 Port Width-4.75 Height-15.5 Length-33 Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted August 4, 2011 Report Share Posted August 4, 2011 That design was from mike at audioque Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Guest Posted August 4, 2011 Report Share Posted August 4, 2011 Dude ur in an ext cab truck u should be able to pull a 150 if ta do it right im in a car with 2 hdc3s and was 143.97 @ 31hz that was the first time i ever metered in my life and it was at the headrest. Btw i wasnt sealed off and i only did 1 run on the meter. This was with 2500rms a 150 with 2 12's on 2000w? good joke Quote Link to comment Share on other sites More sharing options...
