quick fuse question on distrib block
If i have a smaller size fuse in my distribution block than the amount of total amps of fuses that are built in to the amp will the amp get hot becuase my fuse in the distrib block is only letting so many amps through(if that makes any sense lol).. my amp has 4 25amp fuses in it and my distrib block only has a 60 amp fuse.. just installed it and the amp gets hot with plenty air space.. thanks please help me..
pioneer avic-n3 w ipod adapter
clarion eq
infinity kappa perfect 6.1
infinity kappa perfect 5.25
infinity kappa 6x9's
2 boston spg555's
Boston acoustics gt-42
Boston acoustics gt-28
Big 3
Knu 0 gauge
Optima battery
why you not using a 100 amp fuse :nea:
im going too asap.. my block came with it and it was all i had and then my amp started getting hot on my mid n highs and def shouldnt b.. so just hoping this will fix this issue.. someone please help me out.. thx
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
How many channels is the amp, and how many speakers do you have hooked to it?
What kind of amp is it? What kind of fuse is in the distribution block(ANL, AGU, MIDI)?
Boston acoustic gt-42 and the amps fuses are normal car fuses.. the distrib block has agu fuses
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
4ch amp w 2 sets of 4ohm componets on it.. one set on front channels and 0ne set on rear channels
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
That's weird, I could see it maybe getting hot with a 2 ohm load, but not with 4 ohms. Maybe it's just the amps charateristic to run warm. And it's only running 100W RMS, you shouldn't need a monster fuse in the block for it.
also the amp takes 2 pwr wires and 2 gnd wires so should i split the total num in half.. like put a 50 amp fuse on each pwr wire to total the 100 amps the amp has built in or does each pwr wire goin to the amp need a 100 amp fuse on it
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
  • Who's Online   2 Members, 0 Anonymous, 1200 Guests (See full list)
