JBLEEZE33 Posted August 4, 2011 Report Share Posted August 4, 2011 If i have a smaller size fuse in my distribution block than the amount of total amps of fuses that are built in to the amp will the amp get hot becuase my fuse in the distrib block is only letting so many amps through(if that makes any sense lol).. my amp has 4 25amp fuses in it and my distrib block only has a 60 amp fuse.. just installed it and the amp gets hot with plenty air space.. thanks please help me.. Quote pioneer avic-n3 w ipod adapter clarion eq infinity kappa perfect 6.1 infinity kappa perfect 5.25 infinity kappa 6x9's 2 boston spg555's Boston acoustics gt-42 Boston acoustics gt-28 Boston acoustics gt-28 Big 3 Knu 0 gauge Optima battery Link to comment Share on other sites More sharing options...
appi Posted August 4, 2011 Report Share Posted August 4, 2011 why you not using a 100 amp fuse Quote JBL Link to comment Share on other sites More sharing options...
JBLEEZE33 Posted August 4, 2011 Author Report Share Posted August 4, 2011 why you not using a 100 amp fuse im going too asap.. my block came with it and it was all i had and then my amp started getting hot on my mid n highs and def shouldnt b.. so just hoping this will fix this issue.. someone please help me out.. thx Quote pioneer avic-n3 w ipod adapter clarion eq infinity kappa perfect 6.1 infinity kappa perfect 5.25 infinity kappa 6x9's 2 boston spg555's Boston acoustics gt-42 Boston acoustics gt-28 Boston acoustics gt-28 Big 3 Knu 0 gauge Optima battery Link to comment Share on other sites More sharing options...
CleanSierra Posted August 4, 2011 Report Share Posted August 4, 2011 What kind of amp is it? What kind of fuse is in the distribution block(ANL, AGU, MIDI)? Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted August 4, 2011 Report Share Posted August 4, 2011 why you not using a 100 amp fuse im going too asap.. my block came with it and it was all i had and then my amp started getting hot on my mid n highs and def shouldnt b.. so just hoping this will fix this issue.. someone please help me out.. thx How many channels is the amp, and how many speakers do you have hooked to it? Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
JBLEEZE33 Posted August 4, 2011 Author Report Share Posted August 4, 2011 What kind of amp is it? What kind of fuse is in the distribution block(ANL, AGU, MIDI)? Boston acoustic gt-42 and the amps fuses are normal car fuses.. the distrib block has agu fuses Quote pioneer avic-n3 w ipod adapter clarion eq infinity kappa perfect 6.1 infinity kappa perfect 5.25 infinity kappa 6x9's 2 boston spg555's Boston acoustics gt-42 Boston acoustics gt-28 Boston acoustics gt-28 Big 3 Knu 0 gauge Optima battery Link to comment Share on other sites More sharing options...
JBLEEZE33 Posted August 4, 2011 Author Report Share Posted August 4, 2011 why you not using a 100 amp fuse im going too asap.. my block came with it and it was all i had and then my amp started getting hot on my mid n highs and def shouldnt b.. so just hoping this will fix this issue.. someone please help me out.. thx How many channels is the amp, and how many speakers do you have hooked to it? 4ch amp w 2 sets of 4ohm componets on it.. one set on front channels and 0ne set on rear channels Quote pioneer avic-n3 w ipod adapter clarion eq infinity kappa perfect 6.1 infinity kappa perfect 5.25 infinity kappa 6x9's 2 boston spg555's Boston acoustics gt-42 Boston acoustics gt-28 Boston acoustics gt-28 Big 3 Knu 0 gauge Optima battery Link to comment Share on other sites More sharing options...
CleanSierra Posted August 4, 2011 Report Share Posted August 4, 2011 That's weird, I could see it maybe getting hot with a 2 ohm load, but not with 4 ohms. Maybe it's just the amps charateristic to run warm. And it's only running 100W RMS, you shouldn't need a monster fuse in the block for it. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
JBLEEZE33 Posted August 4, 2011 Author Report Share Posted August 4, 2011 also the amp takes 2 pwr wires and 2 gnd wires so should i split the total num in half.. like put a 50 amp fuse on each pwr wire to total the 100 amps the amp has built in or does each pwr wire goin to the amp need a 100 amp fuse on it Quote pioneer avic-n3 w ipod adapter clarion eq infinity kappa perfect 6.1 infinity kappa perfect 5.25 infinity kappa 6x9's 2 boston spg555's Boston acoustics gt-42 Boston acoustics gt-28 Boston acoustics gt-28 Big 3 Knu 0 gauge Optima battery Link to comment Share on other sites More sharing options...
CleanSierra Posted August 4, 2011 Report Share Posted August 4, 2011 I don't see why you would need that much fusing for a 4 channel amp with the power it's pulling. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
