No not at all don't really have another radio... Can you give me a link for the noise filter you are talking about
It's in the radio i think its callled a pico filter or pico fuse you can try grounding your rca's. And that may help with the noise if that is messed up.
@ ingram thats what the noise filters are supposed to do.
@kicker you could look at your rca's and see if you ran them the right way. they usually have arrows. if not. are you using a pre-amp or eq sometimes they are the cause of noise not always your HU so u might wanna try noise filters after that?
no not a pre amp but a real amp yeah
well yes i have a real amp too lol ment a pre amp like an eq. a sound processor of any type. only other thing i can think of is something someone suggested to me. is grounding your RCAs. im running out of ideas lol.
ok so after taking everything apart again i finally found the problem it was my memphis pr1000.1 that i have for my L7 12 it was built in fan that it has i removed the amp and problem solved
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
