qcbangin Posted August 10, 2011 Report Posted August 10, 2011 i'm going to be running 6 D4 10's and don't fully understand how to wire them together. can they be wired to a 1ohm load? if not, how do i wire them to a 2ohm load? any help is much appreciated.
ingramcaraudio Posted August 10, 2011 Report Posted August 10, 2011 1.33 is what it will end up at you need to wire each woofer in series then parallel it after that and you should end up at 1.333. Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
qcbangin Posted August 10, 2011 Author Report Posted August 10, 2011 thanks alot for your help, appreciate it very much. 1.33 is what it will end up at you need to wire each woofer in series then parallel it after that and you should end up at 1.333.
